04-20-2007 10:39 PM - edited 03-11-2019 03:02 AM
Can i use a range of IP on outside interface of pix firewall, and inside host to use one of them randomly? to use PAT on this range?
thank you
04-21-2007 12:10 AM
hello,
yes that is possible.
global (outside) 1 172.16.1.1-172.16.1.20
all inside host will use one of the above defined range ip addresses randomly as they will access outside.
HTH, please rate it
04-26-2007 12:18 AM
thank you ,
can i use these for pix firewall v6.3 ?
04-26-2007 01:01 AM
Yes, this works on both V6 and V7 software.
It doesn't allow for over subscription on the pool so isn't really PAT but more NAT. But that is just splitting hairs.
