VPN Concentrator - Transferring SSL Certificate
Apr 21st, 2007
Dear All,
I have a situation where I have to install an externally signed SSL certificate on a box with different IP addresses then the box from which the enrollement request (CSR file) was generated for this certificate.
I will be very grateful if anyone could advise if this is possible and if yes
then what would be the configuration steps involved on the VPN Concentrator ?.
Kind regards,
Zahid
