How to adjust gatekeeper register timer
Apr 21st, 2007
We use two gatekeepers to maintain failover, so for each gateway, I confiugre like:
interface BVI1
ip address 10.0.56.31 255.255.255.128
h323-gateway voip interface
h323-gateway voip id GK1 ipaddr 142.x.x.11 1719 priority 120
h323-gateway voip id GK2 ipaddr 142.x.x.139 1719
h323-gateway voip h323-id SQPSTN1
h323-gateway voip tech-prefix 1#
h323-gateway voip bind srcaddr 10.0.56.31
This works well when one gatekeeper is down, gateways will register with second gatekeeper. However the problem is, all gateways take over 15 seconds to failover to second gatekeeper. The default register retry and timeout are too long, so I use:
Voice Service
H323
ras timeout grq 3
ras retry grq 1
But this doesn't work, re-register still takes over 15 seconds.
How can I change the register timer?
Wei
teodorgeorgiev Sun, 04/22/2007 - 22:56
I think you should configure RRQ timeout, instead of GRQ timeout.
"ras timeout rrq X"
