SSL VPN & Citrix 4.5
Apr 21st, 2007
Hi Guys,
I am just working on getting SSL VPN going on a 2851. I have it more or less working, but I am getting a message of 'You must configure your browser to accept cookies in order to access the Web Interface.' when trying to access my Citrix session.
I have tested the citrix web session across a regular vpn tunnel and it is working fine.
Has anyone had this experience?
Thanks!
Chris
ivillegas Thu, 04/26/2007 - 10:54
  • Silver, 250 points or more
This message may due to brower does not have SSL certificate.
Try this:
To install the SSL certificate
1. Open a web browser page
2. Go to: tools > Internet options > Content > Certificates > Import > Nest
> Browse the file
This is the procedure to install the certificate. Just be aware that you must provide them
the *.cer file to install it. For this you can export the certificate from your browser
2. Go to: tools > Internet options > Content > Certificates > Trusted root
certification Authorities option, > select your concentrator public ip address > do
a click on export > next > select ?Base-64 encoded X.509 (.CER) > next ( write a
file name) > finish
3. That is the certificate you can provide to your users.
CHRIS YEO Thu, 04/26/2007 - 17:59
Thanks for your response, unfortunately this didn't resolve my issue.
Chris
Jason Nash Thu, 06/21/2007 - 02:21
I am having this same issue with WebVPN on the 3005 VPN Concentrator, running the latest code.
Others on the Citrix forums also seem to be experiencing this issue with the Web Interface on Presentation server 4.5.
Does anyone know of a fix?
halvdommelen Sat, 06/23/2007 - 13:16
Same here on a 3000. I heard that this is a known issue of the Cisco concentrators. Does anyone know when this will be fixed?
Harm van Dommelen
2044418Puts Thu, 06/11/2009 - 04:03
I'm having the same problem on a 2801.
The citrix website appears and then it shows the error metioned by Chris.
Anyone any ideas??
Thanks!
Todd Pula Thu, 06/11/2009 - 08:46
What version of code are you running on your 2801?
CHRIS YEO Thu, 06/11/2009 - 11:42
I have not tried it with the anyconnect client. I have not been back to this since we put everyone in via the full client.
Todd Pula Thu, 06/11/2009 - 08:45
What version of code are you running on your 2851?
