CCM - Avaya integration on an IP trunk
Apr 22nd, 2007
We have CCM 3.3 which has been integrated with avaya s8700 on an ip trunk. The avaya CLAN has been configured as a H323 gateway and a route pattern has been defined to route the calls towards it.
Now i am able to use this route pattern and seize any avaya trunk for making calls but the reverse is not happening i.e from the avaya ip phones i am not able to utilize the channels configured on my VoIP gateway to make outbound calls
Can anyone tell me the configurations that is required to make this happen
I will happy to provide more information if required
thanks in advance
Narayan
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Sun, 04/22/2007 - 06:17
Hi Narayan,
I suppose you configured already the DPs as necessary. Why don't you take a "debug voice dialpeer" and perhaps "show dialplan number" to see if configuration is right. If not sure post the above with config here and explain how the dialplan is.
royalblues Sun, 04/22/2007 - 06:22
Pualo,
Actually i have a DP that points to the avaya gateway so that the cisco users are able to use thid gateway for seizing the trunks.
I do not have a DP/TP for the reverse and iam a bit confused on how to configure it..
Narayan
Paolo Bevilacqua Sun, 04/22/2007 - 07:19
Ah, is not complicated.
dial-peer voice 10 voip
incoming called-number 9T <-- 9 to dial out
direct-inward-dial
If you want to block or treat certain numbers to be called from avaya, just configure called-number differently, with a pattern, or as many DPs as necessary.
If you want to play creative, you can also place a script that plays "Your call is being handled by Cisco technology - Thank you", before connecting the call.
Seriously speaking ans long the avaya can behave on the h.323 leg, it should be fine.
Found this post useful? Rate it using the scrollbox below!
royalblues Sun, 04/22/2007 - 07:38
Paulo,
This would be configured on VoIP gateway.
Do i need to configure anything on the CCM ?
I have the following configuration on the gateway right now
dial-peer voice 5 voip
destination-pattern 8901
session target ipv4:172.20.33.5
dtmf-relay h245-alphanumeric
ip precedence 5
and the following DP's are configured on the CCM
9.!# ---> for cisco voip phones pointing to the gateway
7.[0-9]!# ----> cisco voip phones pointing to avaya CLAN for intercommunication
Narayan
Paolo Bevilacqua Sun, 04/22/2007 - 08:56
this config is for the outbound DP. For inbound, you need should configure as per previous message. Actually you can leave out the direct-inward-dial because it does not apply to incoming voip. The alternative is to configure the avaya so calls intended POTS outbound on cisco GW are sent directly to it, and not to the CCM. Kind of like having two DP on the avaya. This is especially true in the case CCM 3.2 is not able to route the calls on the h.323 trunks, or it does not supports redirection, or the latter is not supported by avaya.
Thanks for the nice rating and let us know if it works!
