CORE HSRP CONFIG
Apr 22nd, 2007
COULD ANYONE TELL ME WHATS WRONG WITH THIS HSRP CONFIGURATION?
THANKS.
NOTE:
interface GigabitEthernet1/1 OF CORE SW 1&2 connected to edge switch 1
interface GigabitEthernet1/2 OF CORE SW 1&2 connected to edge switch 2
VLAN 100 IS THE MANAGEMENT VLAN
CORE SWITCH A
spanning-tree vlan 10 priority 8192
no ip address
switchport
switchport trunk allowed vlan 10,100
no ip address
switchport
interface Vlan10
ip address 172.20.0.252 255.255.255.0
standby 10 ip 172.20.0.254
standby 10 priority 115
standby 10 preempt
standby 10 track vlan 10
CORE SWITCH B
spanning-tree vlan 10 priority 12288
no ip address
switchport
no ip address
switchport
interface Vlan10
ip address 172.20.0.253 255.255.255.0
standby 10 preempt
royalblues Sun, 04/22/2007 - 06:06
  • Green, 3000 points or more
Friend,
i would have configured different HSRP priorities on the core switches.
i.e standby 10 priority 115 on core sw1
and standby 10 priority 110 on core sw2
this would ensure that core switch 1 will be the HSRP active which should be the case as core switch 1 is also your spanning tree root for VLAN 10
As you are tracking vlan 10, whenever there is any problem the priority would be reduced by 10 which will cause the other switch to take the HSRP active role.
HTH, rate if it does
Narayan
cfajardo1_2 Sun, 04/22/2007 - 11:30
sorry that was a typo error.
standby 10 priority 110 is on core switch B.
What about the tracking of vlan 10..Is this right? When Int G0/1 goes down, will vlan 10 goes down too in this case? If not, then what will happen to the edge switch connected to core sw A?
thanks
thanks
jason.plank Sun, 04/22/2007 - 14:04
Tracking logical interfaces isn't a good idea. You would be MUCH better off tracking the physical interface.
Richard Burts Sun, 04/22/2007 - 17:04
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
And it especially does not make sense that configuration of HSRP on VLAN 10 should track VLAN 10.
interface Vlan10
standby 10 preempt
the purpose of track is that if the specified interface goes protocol down then you change your priority. But if VLAN 10 goes protocol down then it will not be possible for interface VLAN 10 to change its priority. If you are going to track interfaces you need to track something other than your own interface.
Rick
cfajardo1_2 Sun, 04/22/2007 - 21:21
hi rick,
could you pls rewrite my hsrp configurtion then.
thanks
cfajardo1_2 Sun, 04/22/2007 - 21:24
so am i ryt if i do the ff;
interface Vlan10
standby 10 preempt
standby 10 track int g0/1
standby 10 track int g0/2
thanks
Anand Narayana Sun, 04/22/2007 - 21:48
  • Silver, 250 points or more
you can also include the "timers" for hello packets & Hold time.
interface Vlan10
standby timers 5 15
standby 10 preempt
