After software update, users are not longer recognized as members of group
Apr 22nd, 2007
Hi!
Today I updated the software version of our VPN 3060 from "Cisco Systems, Inc./VPN 3000 Concentrator Version 4.1.5.A Jul 21 2004 17:54:03" to "Cisco Systems, Inc./VPN 3000 Concentrator Version 4.1.7.Q Feb 20 2007 12:24:30".
After the update, users were no longer able to connect. The following error occurs:
547 04/22/2007 18:06:58.030 SEV=4 IKE/60 RPT=22 xx.xx.xx.xx
User ([email protected]) not member of group (Some Group), authentication failed.
This happens even though some moments before the group was found
543 04/22/2007 18:06:53.010 SEV=5 CERT/105 RPT=25
Group [A_VPN_Group] found for cert peer xx.xx.xx.xx by group match rule
issuer-cn="someca"
The logs of passed authentications at the ACS show:
04/22/2007 18:06:58 Authen OK [email protected] A_Windows_Group xx.xx.xx.xx [email protected] yy.yy.yy.yy[VPNC IP Address]
I don't now what may have happened. Have you got any clues?
Thanks in advance,
Manuel
b.hsu Fri, 04/27/2007 - 05:19
  • Silver, 250 points or more
It may due to Group Attribute configruation in ACS
If the Group Lock feature is enabled on the Group - Tunnel_Group, then the User must be part of Tunnel_Group to connect.
Refer these link:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_tech_note09186a00800948c1.shtml
http://www.cisco.com/en/US/tech/tk59/technologies_configuration_example09186a00800946a2.shtml
ciiscte_admin Fri, 04/27/2007 - 05:40
Thanks a lot. We disabled that feature and it all works perfectly again.
