Unity Port redirect
eschulz Mon, 04/23/2007 - 08:20
This would be controlled by the phone system. If you are using CallManager 4.x or later then you might do this in the HuntList/LineGroup setup. For example, you could add some receptionist phones to a LG and then add that LG to the bottom of Unity's HL.
eschulz Mon, 04/23/2007 - 11:44
You may have better luck with CCM call routing questions on the IP Telephony forum.
One possibility I might guess is that you could create different HuntLists for each AA. Each HL would include the same Unity LineGroups but then could have additional LGs, custom for the AA.
