Error disable snmp traps
Apr 22nd, 2007
Hi all,
I want to enable a 3550 IOS ver 12.1 to send a trap if any ports go into err disable state.
is the: "snmp-server enable traps port-security" the command I am looking for? Is there anything more granular (i.e. it sends traps only if a port is in err-disable).
Thanks in advance,
Andres
carenas123 Wed, 05/02/2007 - 05:13
  • Silver, 250 points or more
To enable SNMP notifications (traps or informs), use the snmp-server enable traps command. To disable all SNMP notifications, use the no form of this command.
snmp-server enable traps [flash [insertion | removal] | fru-ctrl |
port-security[ trap-rate trap-rate] | removal | stpx | vlancreate | vlandelete | vtp]
no snmp-server enable traps flash [insertion | removal] | fru-ctrl |
