PIX 501 to Multi-501 VPN
Apr 22nd, 2007
I'm trying to create an IPSec VPN between a central site with a PIX 501 and two remote sites also with PIX 501s. The Central location currently has 1 public IP with a router performing NAT. The PIX sits directly behind this router. The situation is identical at the remote sites. My initial question is if this is possible?
haroon.shaikh Wed, 04/25/2007 - 19:36
Yes, that is possible.
But, you need to make sure you forward appropriate traffic from the router to the PIX on all branches.
Also, it would be great if you can post a detailed description.
* Please rate if it helps
