multicast
Apr 22nd, 2007
Hi Netpro,
how do i start change the workstream on multicast , currently i am using 224.x.x.x whereby now i wanna change to 239.x.x.x and turn off 224.x.x.x
any idea ?
regards,
Jackal
ankbhasi Sun, 04/22/2007 - 23:55
  • Cisco Employee,
Hi Jackal,
It is very application specific. So can you update which multicast application you are using to generate multicast traffic.
Ankur
ney25 Mon, 04/23/2007 - 01:21
Hi Ankur,
Thanks for reply, well i got the answer already, i would use the ACL to deny 224.x.x.x range and permit from 239.x.x.x
thanks.
Jackal
