wlc 2006 mac filtering
Apr 22nd, 2007
I would like to allow client to access wireless lan based on the client mac-address.
How I config it on WLC 2006 locally (not using radius server)? If yes, How mnay mac-address can be configured on the wlc2006?
Overall Rating: 4.5 (2 ratings)
ankbhasi Mon, 04/23/2007 - 00:53
Hi Douglas,
Yes you can configure mac filtering using local database instead of Radius.
The command to configure or add mac address in mac filter list is
config macfilter add
Have a look at this link
Also I believe max number of entries which you can add in mac filter list is 50.
*Pls rate all helpfull post
rob.huffman Mon, 04/23/2007 - 08:24
Hi Douglas,
Just wanted to add a note to Ankurs good info;
Maximum MAC Filter Entries
The controller database can contain up to 2048 MAC filter entries for local netusers. The default value is 512. To support up to 2048 entries, you must enter this command in the controller CLI:
config database size MAC_filter_entry
where MAC_filter_entry is a value from 512 to 2048.
From this good doc;
MAC Filtering
Hope this helps!
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
