No i don't believe you will be able to do this as you cannot assign 2 ethernet interfaces on the same router to the same subnet. When you come to configure the 2nd ethernet connection you will get an error saying the address overlaps with ether1.
NO, you cannot configure the same subnet on the a same router, because it overlaps & you a message too when you try that.
