snmp traps for switch generate up/down messages
I have this configuration on a Cisco 2960 switch :
logging buffered warnings
logging monitor notifications
logging trap warnings
logging facility local6
logging 192.168.120.222
snmp-server community snmp_community RO
snmp-server enable traps snmp authentication coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps cluster
snmp-server enable traps entity
snmp-server enable traps cpu threshold
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps envmon
snmp-server enable traps mac-notification
snmp-server enable traps copy-config
snmp-server enable traps config
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistenc
We have a syslog server configured at 192.168.120.222.
We don't want to receive interface up/down notifications.
However when an interface goes up or down we still receive that notification despite removing the configuration :
snmp-server enable traps snmp linkdown
snmp-server enable traps snmp linkup.
What configuration is causing these messages to be syslogged ?
regards,
Sebastian
3 Accepted Solutions
bbo
just configure (on a per-interface-basis)
no snmp trap link-status
resp. no logging event link-status
do not confuse between snmp and syslog - they are different protocols with (possibly) different servers
the difference lies between SNMP and Syslog
"no snmp-server enable traps snmp linkup linkdown" disables the sending of SNMP-Traps to your SNMP-Server. However, you don't have any SNMP-Server configured (would be the command "snmp-server host [ip] [community]"), you only have configured a Syslog-Server, sending him Syslog-Messages with Severity warning and higher. Link-Status-Messages have - as I recall - severity 3.
Unless you do not want to set the syslog-severity higher, you should - as bbo described - configure all interfaces with "no logging event link-status".
The difference between the two snmp-traps-link-status-command is the scope: "snmp-server enable traps snmp linkup linkdown" is a global command, which can be overridden by "no snmp trap linkstatus" on each interface. The opposite (no .. in global, snmp trap link-status on interface) is default and results in no SNMP-Link-Status-Traps (but no still Syslog-Messages in your configuration).
Joe Clarke
If it's syslog messages you don't want to see, you will have to do:
Under each interface that should not trigger and up/down message.
5 Replies 5
bbo
What is the difference between "no snmp trap linkstatus" and "no snmp-server enable traps snmp linkup linkdown" ?
They're both snmp traps ?
Joe Clarke
Thanks all,
I think i have to dig in a bit more into snmp versus syslog :)
But for now i've added 2 rules per interface :
gr
Sebastian
