RTMT - CallProcessingNodeCpuPegging
Apr 23rd, 2007
I recently got one of these RTMT alerts (sqlservr (95 percent) uses most of the CPU) during a time when there are little if no usage on the phone system. I checked out the event logs and there was nothing during the particular time frame of the RTMT alert, not even backups. I also checked the Call Detail Reports and saw that there was only 3 calls during that time. Any suggestions?
1 vote
Zin.Karzazi Mon, 04/23/2007 - 06:26
Dont worry about this if it is coming once in a while. However, if you are getting this alert more often check to see if dial tone is delayed when the phone goes off-hook. If you experience delayed dial tone, the high CPU load is affecting your service levels and you should open a TAC Case.
mchandak Mon, 04/23/2007 - 06:58
If this is happening around 2 AM everyday, it could be caused due CDR Load info CAR Database when spikes the CPU. Can u let us know when exactly does this happen. And if there is fixed time of the day when this issue occurs
mchandak Mon, 04/23/2007 - 07:14
What other events are logged in Application Log around the time when you get this high CPU Utilization
cplatt01 Mon, 04/23/2007 - 07:17
A few of these, but these warnings are triggered all day. Other than that, nothing other than ASP informational messages.
(DSA OPERATOR(39) Proc 487, Sev 14)
A checkpoint has been successfully set for the DC Directory Server
Number of Warmstart DA Entries: 1
mchandak Mon, 04/23/2007 - 07:35
These should not affect CM. DC Directory works independant to SQL. And do you see any entries by SQL (Information/Warming/Error) logged at that time ?? or CDR/CAR Insert Service
cplatt01 Mon, 04/23/2007 - 07:36
Only at 2AM, not at 7 AM as indicated by the RTMT alert.
