VPN - SB 101
pkallasidis
Can anybody tell me if you can create a VPN connection with the SB Series
PK
m.sir
Level 7
Level 7
No the IPSEC VPN support is from the Cisco 850 series
Check this link (table 3 Product comparsion)
http://www.cisco.com/en/US/products/ps6216/prod_eol_notice0900aecd805a5a93.html
M.
Thanks for the respond
jonboyle00
I am interested in the answer to this question. Have you found a way to address this. If I disable the firewall I can connect with no problem but when the firewall is enabled that is when I have a problem. I tried SDM tool but I am not sure how to use the features.
Thanks in advance
