Upgrading Cisco 1750/1751 Flash Memory, maximum?
Apr 23rd, 2007
Hi guys,
Need your help on this. Can I know, what is the maximum flash memory capacity can I upgrade on Cisco 1750 & 1751. I need to use minimum 32M of flash memory to upgrade my routers to IOS version 12.3 and up.
And also can I upgrade the memory to 64M? I think there is no problem with the memory upgrade, only concern about the flash upgrade. Especially for 1750 routers.
Thanks.
Overall Rating: 1 (1 ratings)
paolo bevilacqua Mon, 04/23/2007 - 05:51
  • Hall of Fame,
    Founding Member
as fas as I know, you cannot upgrade flash on the 175x. This is even more an issue when running voice features.
