Cisco 1750 & 1751 flash memory maximum upgrade capacity?
Apr 23rd, 2007
Hi guys,
Need your help on this. Can I know, what is the maximum flash memory capacity can I upgrade on Cisco 1750 & 1751. I need to use minimum 32M of flash memory to upgrade my routers to IOS version 12.3 and up.
And also can I upgrade the memory to 64M? I think there is no problem with the memory upgrade, only concern about the flash upgrade. Especially for 1750 routers.
Thanks.
mohammedmahmoud Mon, 04/23/2007 - 05:49
Hi there,
For the 1750 router:
Flash memory - Type: onboard (socketed) miniflash card; default: 4 MB; available sizes: 4, 8, 16 MB; maximum flash: 16 MB; support dual flash bank.
maximum DRAM: 48 MB
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080092102.html
For the 1751:
Cisco 1751 Flash - 32 MB/32 MB
RAM 64 MB/128 MB
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080088719.html
HTH, please rate if it does,
Mohammed Mahmoud.
azmirccnp Mon, 04/23/2007 - 15:54
Hi Mohammed, thanks for your answers. I've a Cisco 1751 with Flash of 16M, can I upgrade it to 32M?
And also, for the 1750, I can't upgrade it to Flash 32M & RAM 64M ??
Thanks.
