port mirroring
Hi All,
I have need to set up a mirrored port on my catalyst 4507 switch. The source port is the firewall port and the destination is a port on which a network sniffer will sit (websense network agent). Apparently I am doing somethign wrong as when i do the monitor sess deal, the port has the line protcol down and it states (monitoring). Why is this? I still need to be able to get out and such on the port. When i view the session it looks like the following:
Session 1
Type : Local Session
Source Ports :
Both : Gi3/4
Destination Ports : Gi3/6
Encapsulation : Native
Ingress : Enabled, default VLAN = 20
Learning : Disabled
TIA,
r
Amit Singh Mon, 04/23/2007 - 09:39
That is the expected behaviour of the " destination port " status. Whenver you conbfigure a port as destination port, it listes you are down/monitoring.If you want to destination port to receive traffic you can enable ingress feature on the switch port using the below command:
Switch(config)# monitor session 1 destination interface fastethernet 5/48 ingress vlan 7
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_31a/config/span.htm#wp1024634
HTH,Please rate if it does.
-amit singh
