CCNP Study - output of "show spanning-tree" command
Apr 23rd, 2007
Is there a good reference on how to interpret the output of this command? I am understanding some areas but others Im not very clear on. Is there any good reference out there for this? Im using the BCMSN v4. Exam Cert Guide, it is ok but I can't really find alot on the output of the command and how to read it. Any help or a point in the right direction would be great! Thanks
royalblues Fri, 04/27/2007 - 11:44
  • Green, 3000 points or more
Try to get hold of CCIE LAN switching --by kennedy Clarke.
Its termed as the Lan switching bible. Haven't seen spanning tree explained in detail as this one does.
It refers yto only CatOS but still very good for understanding tjhe underlying technology
HTH, rate if it does
Narayan
