ACS 3.3.2 directly to ACS 4.1
Apr 23rd, 2007
Hi, in the 4.1 release notes the direct upgrade from 3.3.3 to 4.1 is allowed but I have 3.3.2: have you tested it ?
I don't have 3.3.3 and I'd like to avoid 4.0 upgrade.
thank you
rs
r.spiandorello Tue, 04/24/2007 - 05:10
In 4.1 ACS release-notes I can read the following:
If you are upgrading to ACS 3.3.3 and do not have access to that software, review the README text for
details on the upgrade procedure.
What does it mean ?
dominickv Tue, 04/24/2007 - 13:22
the easiest way is to do a fresh install of 4.1 on the server, open a tac case and have them convert your old database into a 4.1. All sorts of headaches with trying to upgrade
