ISDN Bridging access lists
Apr 23rd, 2007
Hi all.
Hope you can help me here.
I'm setting up an ISDN bridged network in a hub and spoke configuration. In normal circumstances, only the spokes will be allowed to dial the hub. I've configured this with all the timeouts etc and works fine.
However, I would like to set up the hub so it can dial the spokes only for telnet traffic. I know that I will need an access list to do this, but how do I 'map' this access list to the 'dialer map bridge' command thus allowing telnet to dial but nothing else. I currently have
'dialer map bridge name <spoke name> broadcast'
without the spoke phone number to prevent it dialing.
Bernie
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Mon, 04/23/2007 - 14:37
I suggest you do not bridge over ISDN, because beside other problems, you cannot filter or trigger dialer based on L3 parameters, as you just have found.
What is forcing you to bridge for this design ?
Bernard Steadman Mon, 04/23/2007 - 23:36
Thanks for your reply.
Unfortunatly, the 'designers' of the networks I have to administer do not have the knowledge of how they work. They just tell us to do it, get it working, but don't come to us when it doesn't. All, of course, without any finacial cost.
Private IPs is not an option so we cannot route to the remote sites without great expense. Therefore I'm forced to use the spare addresses within the Hubs LAN. So bridging is the only option (unless anyone can think of another soloution).
Bernie
Paolo Bevilacqua Tue, 04/24/2007 - 04:31
I understand you frustration but this could be a good occastion to explain the customer why the "designers" made a poor job and things must be changed now.
You will find pleaty of documents on CCO to support you.
Also if you cannot do NAT but need to put some IPs taken from the LAN, remotely via ISDN, you can do that with routing and it will work nice. The router with ISDN will proxy-arp for the remote IP's once they are connected.
Paolo Bevilacqua Tue, 04/24/2007 - 06:04
Thanks for the nice rating, good luck, and come back in case of problems with routing. Almost all can be fixed.
Bernard Steadman Tue, 05/08/2007 - 22:59
Hi all,
I still have a problem with this. I had a trial set up, using a 801 for the spoke and a 2522 for the hub. Link came up and passed traffic. The 2522 was then swapped for a 3620 with 8 port bri, and NM2FE2W loaded with WIC2Ts. The config from the 2522 was mirrored across to the 3620 with modifications for the change of hardware.
The link now comes up but does not pass traffic. Suggestions please.
Edited sho ver and sho run of the 2522 and 3620 are below. IP addresses have also been edited.
2522
System image file is "flash:igs-i-l.110-13", booted via flash
cisco 2522 (68030) processor (revision M) with 2048K/2048K bytes of memory.
Processor board ID 12021904, with hardware revision 00000003
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
Basic Rate ISDN software, Version 1.0.
1 Ethernet/IEEE 802.3 interface.
2 Serial network interfaces.
8 Low-speed serial(sync/async) network interfaces.
1 ISDN Basic Rate interface.
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
2522#sho run
(edited)
hostname 2522
enable secret 5 (edited)
username 2522 password 7 (edited)
username 801 password 7 (edited)
no ip routing
isdn switch-type basic-net3
interface Ethernet0
ip address xxx.153.73.222 255.255.254.0
no ip mroute-cache
no ip route-cache
bridge-group 1
(edited)
interface BRI0
no ip mroute-cache
encapsulation ppp
no ip route-cache
dialer idle-timeout 60
dialer map bridge name 801 broadcast
dialer-group 1
no fair-queue
ppp multilink
ppp authentication chap
bridge-group 1
ip classless
dialer-list 1 protocol bridge permit
bridge 1 protocol ieee
bridge 1 priority 1
(edited)
end
3620
System image file is "flash:c3620-i-mz.122-27b.bin"
cisco 3620 (R4700) processor (revision 0x81) with 24576K/8192K bytes of memory.
Processor board ID 29402708
R4700 CPU at 80Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
4 Serial(sync/async) network interface(s)
8 ISDN Basic Rate interface(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
sho run
Current configuration : 3143 bytes
(edited)
hostname 3620
username 3620 password 7 (edited)
ip subnet-zero
no ip routing
no ip domain-lookup
interface BRI0/0
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer-group 1
no fair-queue
no cdp enable
ppp multilink
bridge-group 1
bridge-group 1 spanning-disabled
(edited)
interface FastEthernet1/0
no ip route-cache
no ip mroute-cache
speed 10
half-duplex
bridge-group 1
(edited)
ip classless
bridge 1 priority 1
(edited)
end
Bernie
