Error loading system image
Apr 23rd, 2007
I recently configured a Catalyst 3560G and noticed that the ip ssh commands were not available. So I downgraded from IOS ver c3560-ipservices-mz.122-25.SEE2 to c3560-ipservicesk9-mz.122-25.SEB4. After downgrading, the ssh commands were available but I get a error message when I do a reload. Any ideas:
Loading "c3560-ipservicesk9-mz.122-25.SEB4.bin"...c3560-ipservicesk9-mz.122-25.SEB4.bin: no such device
Error loading "c3560-ipservicesk9-mz.122-25.SEB4.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c3560-ipservicesk9-mz.122-25.SEB4.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:/c3560-ipservicesk9-mz.122-25.SEB4.bin" uncompressed and installed, entry point: 0x3000
executing...
Overall Rating: 5 (2 ratings)
Amit Singh Mon, 04/23/2007 - 09:42
  • Cisco Employee,
Please paste the output of " show flash:" " show bootvar ", if its there.It seems like the switch is unable to findout the file in the bootpath string, that's why it gave an error.
Please the config also.
-amit singh
vjvelazquez Mon, 04/23/2007 - 10:54
Directory of flash:/
2 drwx 128 Mar 1 1993 16:12:06 -04:00 c3560-ipservices-mz.122-25.SEE2
406 -rwx 109 Feb 28 1993 20:08:16 -04:00 info
407 -rwx 736 Feb 28 1993 20:01:27 -04:00 vlan.dat
3 -rwx 6056 Feb 28 1993 20:03:23 -04:00 config.text
409 drwx 0 Mar 1 1993 16:02:35 -04:00 test
410 -rwx 3422 Feb 28 1993 22:06:03 -04:00 backup-config
412 -rwx 46 Feb 28 1993 20:03:23 -04:00 private-config.text
413 -rwx 6971648 Feb 28 1993 20:35:54 -04:00 c3560-ipservicesk9-mz.122-25.SEB4.bin
411 -rwx 1048 Feb 28 1993 20:03:23 -04:00 multiple-fs
show boot
BOOT path-list : flash
BOOTHLPR path-list : c3560-ipservicesk9-mz.122-25.SEB4.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : yes
royalblues Mon, 04/23/2007 - 11:05
  • Green, 3000 points or more
What happens when you try
Boot system flash:c3560-ipservicesk9-mz.122-25.SEB4.bin from the rommon mode
Narayan
vjvelazquez Mon, 04/23/2007 - 11:50
switch: boot c3560-ipservicesk9-mz.122-25.SEB4.bin
Boot process failed..
Amit Singh Mon, 04/23/2007 - 20:31
  • Cisco Employee,
Do this:
Config t
switch(config)# boot system flash:c3560-ipservicesk9-mz.122-25.SEB4.bin
Ctrl+Z
Wr mem
Reload...
Check if you still get that error.Paste the booting sequence..
-amit singh
vjvelazquez Wed, 04/25/2007 - 05:14
Still get error:
AUCORESW1-STANDBY(config)#boot system flash:c3560-ipservicesk9-mz.122-25.SEB4.$
AUCORESW1-STANDBY(config)#^Z
AUCORESW1-STANDBY#wr m
*Mar 2 12:37:16.479: %SYS-5-CONFIG_I: Configured from console by consoleem
Building configuration...
[OK]
AUCORESW1-STANDBY#reload
Proceed with reload? [confirm]
*Mar 2 12:37:23.534: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
Base ethernet MAC Address: 00:19:e8:16:a1:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 405 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32514048
flashfs[0]: Bytes used: 8709632
flashfs[0]: Bytes available: 23804416
flashfs[0]: flashfs fsck took 7 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
done.
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 17:56 by yenanh
Image text-base: 0x00003000, data-base: 0x00FC1DF8
Initializing flashfs...
flashfs[1]: 405 files, 7 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32514048
flashfs[1]: Bytes used: 8709632
flashfs[1]: Bytes available: 23804416
flashfs[1]: flashfs fsck took 1 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
front_end/ (directory)
extracting front_end/fe_type_1 (34696 bytes)
extracting front_end/front_end_ucode_info (43 bytes)
extracting ucode_info (76 bytes)
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Waiting for Port download...Complete
Amit Singh Mon, 04/23/2007 - 21:54
  • Cisco Employee,
Narayan,
I think the boot path was not set for the image, that's why it wasnt booting properly. Check the output of Show boot , there is not boot path list defined. I think setting the boot path using " boot system flash " command should solve the issue here. There is not need to upload the image again using Xmodem.
-amit singh
royalblues Mon, 04/23/2007 - 22:23
Can we use this command under the Rommon?
vjvelazquez Wed, 04/25/2007 - 05:19
*Feb 28 20:28:35.762: %SYS-5-CONFIG_I: Configured from console by consoleem
[OK]
*Feb 28 20:28:42.096: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
done.
executing...
royalblues Wed, 04/25/2007 - 05:38
Even though you are having a 3560, it sysmptoms indicate that u r hitting the possible bug CSCef23660
Can you try uploading an IOS with a different major version and check
Narayan
vjvelazquez Wed, 04/25/2007 - 08:03
I tried c3560-ipservicesk9-mz.122-25.SEE3.bin and get:
done.
Loading "flash:/c3560-ipservicesk9-mz.122-25.SEE3.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:/c3560-ipservicesk9-mz.122-25.SEE3.bin" uncompressed and installed, entry point: 0x3000
executing...
royalblues Wed, 04/25/2007 - 08:11
from the output it can be interpreted that the switch istrying to load the old image SEB4.bin and is failing.
It then tries to load the new image.
IF the loads properly after that, you can check the current IOS running on the switch via the sh ver command
Narayan
vjvelazquez Wed, 04/25/2007 - 08:16
The show version shows the proper IOS version is loaded but should I be concerned that I am still getting error messages because it's trying to load a previous version of IOS then loads a more current version?
AUCORESW1-STANDBY#sho ver
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(25)SEE3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 22-Feb-07 15:39 by myl
Image text-base: 0x00003000, data-base: 0x011DEC74
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWARE (fc1)
AUCORESW1-STANDBY uptime is 12 minutes
System image file is "flash:/c3560-ipservicesk9-mz.122-25.SEE3.bin"
Never mind I figured it out..For those of you experiencing this issue here it is:
1. if you have a directory within flash: Basically anything that has drwx in front of the file.  For the 3750e's it seems as it looks into the directory for the boot system file, in this case the .bin:  So place the new IOS inside the directory and remove the old one. Then exit the directory get into config mode.
Switch# boot system /directory/new_IOS.bin
Switch# wr mem
Switch# reload.
This should do the trick.
Hope this helps.
Roderick Groesbeek Tue, 06/04/2013 - 09:41
Nope seems that is not doing the trick..
switch: dir flash:
    2  -rwx  10828                    vlan.dat
    4  -rwx  13509527                 conf
    5  -rwx  3096                     multiple-fs
    6  -rwx  1938                     private-config.text
    7  drwx  512                      c3560c405ex-universalk9-mz.122-55.EX2
  451  drwx  512                      c3560c405-universalk9npe-mz.122-55.EX3
  450  -rwx  1189                     config.text
13133312 bytes available (44798464 bytes used)
Unknown cmd:
switch: dir flash:c3560c405-universalk9npe-mz.122-55.EX3
Directory of flash:c3560c405-universalk9npe-mz.122-55.EX3/
    3  -rwx  13508392                 c3500c405-universalk9npe-mz.122-55.EX3.bin
switch: dir flash:c3560c405ex-universalk9-mz.122-55.EX2
Directory of flash:c3560c405ex-universalk9-mz.122-55.EX2/
    8  drwx  5632                     html
  448  -rwx  14043199                 c3560c405ex-universalk9-mz.122-55.EX2.bin
  449  -rwx  400                      info
switch: boot flash:c3560c405-universalk9npe-mz.122-55.EX3/c3500c405-universalk9npe-mz.122-55.EX3.bin
Loading "flash:c3560c405-universalk9npe-mz.122-55.EX3/c3500c405-universalk9npe-mz.122-55.EX3.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:c3560c405-universalk9npe-mz.122-55.EX3/c3500c405-universalk9npe-mz.122-55.EX3.bin" uncompressed and installed, entry point: 0x3000
executing...
NFRWWT Internal Mon, 02/03/2014 - 10:18
I am having this issue as well. Any update on what you did to fix this issue?
craig_tweedie Fri, 05/23/2014 - 17:07
The problem is that you are not completing the path to the file you want to boot from - you need to a forward slash after flash:/ - this is the sequence:
en
conf t
boot system flash:/c3560c405-universalk9npe-mz.122-55.EX3/c3500c405-universalk9npe-mz.122-55.EX3.bin
Peter Valdes Sun, 06/15/2014 - 16:27
Just type the command under global config
"no boot system switch"
reload and error message gone.
As long as you verified /MD5 on the IOS prior to applying the version and reloading the node, should be fine. The switch/router will always fine a valid IOS on the flash unless prompted to look at TFTP.
Peter
Stefan Timuta Sat, 03/25/2017 - 10:42
The command: "no boot system flash" (or switch) actually says, ignore all the boot system commands that are configured on the Switch or Router and just load the IOS image available in the flash.
The command: "boot system flash:c3560-ipservicesk9-mz.122-55.SE10.bin" is the correct one. Bear in mind that everything here it's case sensitive and that the order in which you specify this commands for booting the IOS image is very important.
The one you entered is incorrect, is just an incorrect, and in this case the Switch just says: "Oh, I'm trying to boot the image from the configuration file but the first command is incorrect and there are no more boot system commands, ok, I'll skip this and load the IOS image from flash if it's available."
Stefan
shawpoles Thu, 07/20/2017 - 14:02
Correct command :  boot system flash:New_OS.bin
The "flash:" part was the fix for me.
