Video Advantage and Polycom SCCP VSX 7000
Apr 23rd, 2007
I try to call Polycom VSX 7000 SCCP with my VT Advantge Camera. The video did not start on the PC and on the Polycom.
Is it possible to make those 2 products work together?
Frank
ssoberlik Fri, 04/27/2007 - 10:33
  • Bronze, 100 points or more
Yes they are compatible. Polycoms support G.711a/u, G.728 and G.722/.1 codecs. So the only common codec is G.711a/u .For supplementary services like Call transfer, Call Park you need VSX Polycoms with revision 7.0 software. The VTA supports H.263 and not H.261 which should be fine since the Polycoms do as well
f.lemieux Fri, 04/27/2007 - 12:50
SO vsx 7000 with sccp 8.6 and vt advantage should by OK???
