LMS 2.6 Changed IP address of server.
Apr 23rd, 2007
The admin needed to change the IP address of the server, the hostname has not changed. I have having a problem with the Common Services->Device and Credentials-> Device Management, when I click on this, I get the following message:
Error in communicating with DCA Server.
DCA Server may be down. Please start the DCA Server and then refresh the page.
Joe Clarke Mon, 04/23/2007 - 07:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Was dmgtd restart after the IP address change? What is the state of DCRServer?
ereinoehl Mon, 04/23/2007 - 07:47
I restarted the server after the address change. How do check the state of the CDRServer, I thought I found where to check it, and I believe it is up.
Joe Clarke Mon, 04/23/2007 - 07:49
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
pdshow DCRServer will show you the current state.
ereinoehl Mon, 04/23/2007 - 07:50
C:\Program Files\CSCOpx\bin>pdshow DCRServer
Process= DCRServer
State = Running normally
Pid = 7640
RC = 0
Signo = 0
Start = 4/23/2007 10:12:06 AM
Stop = Not applicable
Core = Not applicable
Info = DCRServer is up and running
Joe Clarke Mon, 04/23/2007 - 08:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please provide the output of the set DOS command as well as NMSROOT\MDC\etc\regdaemon.xml.
ereinoehl Mon, 04/23/2007 - 08:05
C:\Program Files\CSCOpx\bin>set
AdminEmail=[email protected]
ALLUSERSPROFILE=C:\Documents and Settings\All Users
APPDATA=C:\Documents and Settings\Administrator\Application Data
CLIENTNAME=Console
ClusterLog=C:\WINDOWS\Cluster\cluster.log
CommonProgramFiles=C:\Program Files\Common Files
COMPUTERNAME=CISCOWORKS2
ComSpec=C:\WINDOWS\system32\cmd.exe
CWMIBDIR=C:\PROGRA~1\CSCOpx\objects\share\mibs
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\Administrator
LM_LICENSE_FILE=C:\PROGRA~1\CSCOpx\objects\smarts\conf\trial.dat.DFM
LOGONSERVER=\\CISCOWORKS2
NUMBER_OF_PROCESSORS=2
OS=Windows_NT
Path=C:\PROGRA~1\CSCOpx\objects\smarts\lib;C:\PROGRA~1\CSCOpx\objects\smarts\bin
;C:\PROGRA~1\CSCOpx\campus\bin;C:\PROGRA~1\CSCOpx\MDC\tomcat\bin;C:\PROGRA~1\CSC
Opx\MDC\Apache;C:\PROGRA~1\CSCOpx\MDC\jre\bin;C:\PROGRA~1\CSCOpx\MDC\bin;C:\PROG
RA~1\CSCOpx\lib\jre\bin\server;C:\PROGRA~1\CSCOpx\objects\db\win32;C:\PROGRA~1\C
SCOpx\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 6, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=0f06
PROMPT=$P$G
SESSIONNAME=Console
SM_BROKER=ciscoworks2:9002
SM_HOME=C:\PROGRA~1\CSCOpx\objects\smarts
SM_RULESET_PATH=C:\PROGRA~1\CSCOpx\objects\smarts\rules
SM_SITEMOD=C:\PROGRA~1\CSCOpx\objects\smarts\local;C:\PROGRA~1\CSCOpx\objects\sm
arts
SM_SNMP_BUG_COMPATIBLE=1
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp
TMP=C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp
USERDOMAIN=CISCOWORKS2
USERNAME=Administrator
USERPROFILE=C:\Documents and Settings\Administrator
windir=C:\WINDOWS
Joe Clarke Mon, 04/23/2007 - 08:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This looks okay. What are your service startup parameters for the CiscoWorks services? Also provide the NMSROOT\log\dcr*.log files.
ereinoehl Mon, 04/23/2007 - 08:20
This is the dcrimpexp.log:
[ Fri Apr 13 12:05:53 EDT 2007 ] INFO [SystemPrefAction : dnsResolutionStatus] : Finding the dns Resolution status
[ Fri Apr 13 12:05:53 EDT 2007 ] INFO [SystemPrefAction : dnsResolutionStatus] : The DNS Resolution status is 0
Joe Clarke Mon, 04/23/2007 - 08:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I see some potential problems here that point to some possibly corrupt or out-dated class files. At this point, it would be a good idea to open a TAC service request so additional DCR debugging can be enabled. If you have applied any CiscoWorks patches recently, you should try backing them out to see if that resolves this problem.
