darpotter Tue, 04/24/2007 - 02:27
  • Silver, 250 points or more
I assume the error you get is when trying to configure the ODBC settings?
You'll need to look in the CSAdmin service log file (ADM.log) and search for "ODBC".
Also you can try setting logging to max then run a "net start/stop csadmin" and then try to navigate to the config page.
It could be the ODBCAuth Dll is not loading properly, or once loaded could be going wrong because of any number of reasons.
You'll probably have to end up going to TAC with the ADM log - although I dont mind taking a look.
Darran
hoogen_82 Wed, 04/25/2007 - 02:35
Hi Darran,
Thank you for your help. I was able to locate the admn.log file only. Is that what you are looking for. I am attaching the logs for youre reference.
-Hoogen
