Cisco 3750
Apr 23rd, 2007
Switch seemed to stop routing traffic as it should. It was the core switch. Replaced with a Cisco 4506 (much happier now with performance :))
Should I just reload the IOS on the 3750 from scratch or send it back to Cisco to be looked at and repaired if needed??
I was thinking of getting it repaired then putting it back online and creating a routing group for redundency in case the 4506 went down. Any thoughts??
Amit Singh Mon, 04/23/2007 - 09:46
  • Cisco Employee,
Is it faulty?? What was the exact problem that you faced?
If the switch is faulty and has some hardware/software problems, then you can get a replacement from Cisco. If the switch is not faulty, then try reloading a new IOS and keep it with you for a worse case.
-amit singh
ankbhasi Mon, 04/23/2007 - 09:46
  • Cisco Employee,
Hi Friend,
As you mentioned routing was not working as expected and with this statement even TAC will not be able to fin out what was the problem and what happened that time period.
Even if u sent the switch back to us it will not help you out with anything as you may get a replacement which may result in same issue. So till the time we can find out the root cause I will not recommend to send the switch back to us.
I will recommend to reload the switch once and use it in your routing domain for redundancy and by anychance if problem appears again then it will be best time to find out the root cause and they you may take decision to return the product or not.
Ankur
gzbrowniii Tue, 04/24/2007 - 04:01
Thanks. I upgraded the IOS on it and have it on the network to test.
