Cat 6500
Apr 23rd, 2007
Hi Guys,
Hopefully we are getting our first 6500. At this point the major features we want are:
1) Layer 3 switching with OSPF
2) SLB
So we got the following component list from our supplier:
Catalyst 6500 Enhanced 9-slot chassis,15RU,no PS,no Fan Tray
Cisco CAT6000-SUP32 IOS IP BASE (MODULAR)
Catalyst 6500 Supervisor 32 with 8 GE uplinks and PFC3B
Catalyst 6500 48-port 10/100/1000 w/Jumbo Frame, RJ-45
Catalyst 6509-E Chassis Fan Tray
Catalyst 6500 3000W AC power supply (spare)
Is this list what we want to at the least support the requirements?
Thanks!
Jacques
Overall Rating: 5 (1 ratings)
royalblues Mon, 04/23/2007 - 10:20
  • Green, 3000 points or more
Friend,
The configurations looks fine except for the IOS.
you cannot run OSPF on an IP base image. you would require an IP services image.
you can choose Cisco CAT6000-SUP32 IOS IP SERVICES -- S323IS-12218SXF
HTH, rate if it does
Narayan
jacquesd Mon, 04/23/2007 - 12:08
Hi Narayan,
Thanks a lot. I will ask them to revise the quote.
Thanks!
Jacques
