WIFI VLANs not communicating
Apr 23rd, 2007
I'm trying to set up 1130 APs connected to a 3750 L3 switch. I set up 3 SSIDs : test,
internal and guest. For some reason, I can't access the APs when the port is configured for trunking. I did the same on a 3560 switch with 2 SSIDs last week, and I'm getting
very different results.
Test: 10.10.10.x Native VLAN 1
Internal: 192.168.10.x VLAN 203
Guest : 192.168.100.x VLAN 202
I connect to the AP fine, but when I connect to 'internal' SSID, I can only communicate
if my IP is on the 192.168.10.x range, even though the 'test'VLAN is set to a different
subnet.
The switch port configs:
interface GigabitEthernet1/0/7 ! ---I can access the AP
switchport access vlan 203
interface GigabitEthernet1/0/8 ! ---no communication---
switchport mode trunk
The AP config:
The AP config should be attached
I'm stuck, I have no idea what I'm doing wrong, PLEASE HELP :)
Chris Serafin
[email protected]
[email protected]
john.preves Mon, 04/23/2007 - 10:21
  • Silver, 250 points or more
These sound like autonomous AP's.
All the ports should be trunked and the native vlan needs to be defined.
Int g1/0/7 has a vlan 203 defined which is why you can get to the AP, g1/0/8 has no vlan
try this:
switchport trunk native vlan 1
switchport trunk allowed vlan 1, 202-203
Try this on one and test it. Then populate the rest of the switch
cisco80211 Mon, 04/23/2007 - 10:51
I have tried this and 2 of the commands do not show up in the config. (must be default configs)
after:
no switchport access vlan 203
switchport trunk encap dot1q
switchport trunk allowed vlan all
this shows in the config:
description [ Link to AP7 ]
Thanks for your original response.
Chris Serafin
[email protected]
3iadministrator Mon, 04/23/2007 - 19:05
Not too sure on your case though.I am using 1130 as Lightweight mode,which let the Wireless controller do the configuring.
But one thing for sure, Your AP-Manager and Management Interfaces is recommended to be on the same vlan.hopes that help.
john.preves Mon, 04/23/2007 - 20:47
I would at this point write erase and reload the switch and clear out whatever may be lurking in there.
jgonzal84 Fri, 05/25/2007 - 12:37
Your getting barked by the switch because you did not set up those vlan's.. I think... Try issuing this statement in config mode
int vlan 202
no shut
int vlan 203
no shut
then go to the interface 1/07 and reissue the statements..
Do a show vlan in global mode to see if your vlan are there..
Hope this works for you..
ibrunello Tue, 06/05/2007 - 09:02
it worked for me.
I don't have (yet) a VTP domain, so I need to configure vlan on each switch.
Adding it (via the "vlan database" command, since it is an L2 device), and it started working.
ericgarnel Tue, 06/12/2007 - 06:32
  • Gold, 750 points or more
I may have missed it, but where is your layer 3 device/config that lets the seperate vlans communicate with each other?
rajinder63 Sat, 07/14/2007 - 06:39
can u please change ur native Vlan1 to native vlan203 , u will be accessing then .. no issue .. try it ..
jwadleigh Fri, 08/24/2007 - 10:35
Keep in mind that only the link between the WLC and the wired network should be trunked.
The AP's should be plugged into Access ports.
rgnelson Mon, 08/27/2007 - 08:16
Correct - sorta. If H-REAP is to be used, the AP is then connected to a trunk port.
