router simulators (boson vs routersim vs ??others)
Apr 23rd, 2007
I am researching my purchase of router simulators. Looks like the two biggest players are BOSON vs RouterSim.
Does any one have experience with both to give their personel recommendation
Overall Rating: 3 (1 ratings)
farhan_p2000 Tue, 04/24/2007 - 08:48
Hi Etienne,
Plz guide as to how this software is to used.
Have used Boson and found it to be pretty good.
etienne.basset Tue, 04/24/2007 - 10:17
here is a brief overview, please read dynagen / dynamips site info for more details
a) download winpcap 4.0 and install it.
b) download dynagen and install it
c) put IOS for a a supported platform in directory
d) edit one of the file
image = \Program Files\Dynamips\images\MATCH-YOUR-IOS
npe = npe-400
ram = 160
console = 2001
f0/0 = LAN 1
model = 7200
console = 2006
f0/0 = LAN 1
s3/0 = R3 s3/0
console = 2003
f0/0 = LAN 2
model = 7200
e) start dynamips server
f) start your lab by double clicking it
g) from the console, telnet R1 etc
jsadofsky Wed, 05/02/2007 - 13:13
What if you dont have access to IOS.
IOS is a purchased item correct?
Alf Martinsen Wed, 04/25/2007 - 01:12
I have used both of them, but after going for the first of my CCNA exams, i throw them away. There is some lack of functionality in them. One was the lack of passive-interface cmd, etc. You want be able to actually see, what's going on on the switches and routers, what if you plug in wrong cable, snap it out, config register changes, + +
All those debug commands! they are VERY important to know and use, so that you could actually see, what's going on.
My advice, drop sim's, by real equippment on ex e-bay, etc. You would get so much broader, and practially experience.
faisal.saleem Wed, 05/02/2007 - 05:32
Agreed to Etienne ,nobody should use other simulators for routing labs and additionally you cannot do some switching labs on dynamips.
Here are my some few cents for on that gr8 software, hopfully it will help for newusers.
(i also capture this whole internetwork tutorial and upload it at ==> hxxp://
so u no need to still watch it online)
For linux users ==>hxxp://
official forum==>hxxp://
farhan_p2000 Wed, 05/02/2007 - 22:53
Thanks Etienne and Faisal for the technical info about the software.
Man, this topic just got more interesting.
Never knew, ppl were using simulators for CCIE as well.
Always thought of the road to CCIE to be longer.
Thanks guys!!
Any links where you can download IOS's???
