Cordless handset for IP Communicator
Apr 23rd, 2007
Anybody found a cordless handset that will work with IP Communicator?
jconi Mon, 04/23/2007 - 23:43
Hello Brandon,
I use the Plantronics CS50 (quite expensive), and it works fine with IP Communicator. Moreover, with the Personocall Software that you install on the PC, you can answer a call by clicking on a button on the headset. It works fine too.
Now GN Netcom does also this functionnality.
Brandon Buffin Tue, 04/24/2007 - 04:17
Thanks for the information, but I am actually looking for a handset as opposed to a headset. Clarisys makes the i750H that works well with IPC, but I'm looking for something cordless.
