How TO: Setup WPA on AP1200
Answered Question
Apr 23rd, 2007
Hello - a bit confused on how to go about setting up WPA security on the AP 1200.
Searching for steps but have not found any yet. Anyone? Thanks
Correct Answer by jreekers about 9 years 6 months ago
you should have them now. Good Luck!
Overall Rating: 5 (2 ratings)
jreekers Mon, 04/23/2007 - 12:13
Here is a document which shows how to configure WPA on your access point.
In order to configure the AP for WPA you need to configure EAP on you AP as well, which is not mentioned in the above document. So here is another document which tells how to configure EAP on your AP. You just need to follow the part shown for the access point only & not the ACS part in the document.
Hope this helps.
planzone Mon, 04/23/2007 - 12:30
I appreciate the reply. However I receive:
The Page You Have Requested Is Not Available
I am aware the link is wrapped and made sure I had all the infoentered correctly in the browser but unable to get to the docs. Anyone else can get to them? If not does anyone else have any hints or tips and step by step hot to?
planzone Mon, 04/23/2007 - 12:37
LOL. No for some reason I connot.. I am logged in as well. Do I need higher access lol
Perhaps directly emailing to me?
jreekers Mon, 04/23/2007 - 13:56
...very should be able to see it, as it's on the public site. Send me an email and I'll reply to it with the documents attached.
PS. Please don't forget to rate this conversation. ;-)
Correct Answer
jreekers Mon, 04/23/2007 - 14:09
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
