Vonage not working behind Cisco 3620 Router
Paolo Bevilacqua Mon, 04/23/2007 - 12:27
IOS running on the 3620? You need something recent that supports SIP. I have SIP and SCCP clients behind 12.4T and works fine.
Hope this helps, if so please rate post!
How do I configure SIP properly. I keep getting, "Vonage device cannot connect to the vonage network". Here is my show version output. It does supprt SIP.
"Cisco Internetwork Operating System Software
IOS (tm) 3600 Software (C3620-IK9O3S6-M), Version 12.3(18), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Wed 15-Mar-06 22:18 by dchih
Image text-base: 0x60008B00, data-base: 0x61A1C000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ROM: 3600 Software (C3620-IK9O3S6-M), Version 12.3(18), RELEASE SOFTWARE (fc3)
DEFCON-WAN-ROUTER uptime is 11 hours, 27 minutes
System image file is "flash:c3620-ik9o3s6-mz.123-18.bin"
Paolo Bevilacqua Tue, 04/24/2007 - 03:39
there is nothing special in Vongaes, I assume you NAT config is OK. Check with "show ip nat translatations" that the translation in created as expected.
Beside that I wouldn't know what to say.
interface Ethernet0/0
description WAN INTERFACE TO COX ISP
bandwidth 10000
ip address dhcp
ip access-group External in
ip nat outside
ip multicast ttl-threshold 8
ip multicast tagswitch
full-duplex
no keepalive
arp timeout 300
no cdp enable
interface FastEthernet1/0
description DMZ INTERFACE TO LAN USERS AND WIRELESS USERS
bandwidth 100000
ip verify unicast reverse-path
no ip proxy-arp
ip nat inside
ip multicast ttl-threshold 2
speed 100
full-duplex
arp timeout 60
no cdp enable
interface FastEthernet1/1
description VONAGE LINK
bandwidth 100000
ip address 192.168.2.1 255.255.255.0
ip access-group vonage_inbound in
ip access-group vonage_outbound out
no ip proxy-arp
ip nat inside
no ip mroute-cache
speed 100
full-duplex
arp timeout 60
no cdp enable
ip nat log translations syslog
ip nat translation timeout 120
ip nat translation dns-timeout 5
ip nat inside source list 1 interface Ethernet0/0 overload
ip nat inside source static udp 192.168.255.254 161 65.182.16.88 161 extendable
ip nat inside source static udp 192.168.255.254 162 65.182.16.88 161 extendable
ip nat inside source static udp 192.168.1.1 161 65.182.16.88 161 extendable
ip nat inside source static udp 192.168.1.1 162 65.182.16.88 162 extendable
access-list 1 permit 65.182.16.88 log
access-list 1 permit 192.168.0.0 0.0.0.255 log
access-list 1 permit 192.168.1.0 0.0.0.255 log
access-list 1 permit 192.168.2.0 0.0.0.255 log
access-list 1 permit 192.168.3.0 0.0.0.255 log
access-list 1 permit 192.168.4.0 0.0.0.255 log
access-list 1 deny any log
Paolo Bevilacqua Wed, 04/25/2007 - 03:57
NAT config seems fine. Can you try without the ACL vonage_inbound and vonage_outbound ?
How the vonage ATA gets an addess? Can you ping this address?
Paolo Bevilacqua Thu, 04/26/2007 - 08:22
How the vonage ATA gets its address ?
Until you can ping it, I would say no chances to have it working.
a.cruea1980 Sat, 04/28/2007 - 18:39
I ended up having to create a NAT rule and open up UDP 10000 to keep my Vonage ATA working properly. Just a suggestion. I never had to enable SIP or SCCP through my router, either.
YMMV, though.
a.cruea1980 Sat, 04/28/2007 - 19:18
Nah, I use DHCP also and keep up a translation like so:
ip nat inside source static udp 192.168.0.10 10000 interface FastEthernet4 10000
That's what I use for my Vonage, works well. Not sure if it's totally needed, though. Like I said, once I popped open UDP port 10000 in my ACL, it stayed connected to Vonage's network. I just have the nat translation there *just in case*.
How are you assigning your Vonage ATA an address, though? DHCP or static?
"How are you assigning your Vonage ATA an address, though? DHCP or static?" <--- what do you mean bythat. I can't remember how I set it up originally. But it was behind a Netgear router. Then that stopped working, so I put it behind the d-link and it didn't work. Thn I put the cisco 3620, before the D-link router and off another fa link put the vonage diretly connectedvia crossover (straight through cable wouldn't get a link). Do I have to specify my WAN IP with vonage. I remeber something about a MAC address before.
a.cruea1980 Sun, 04/29/2007 - 13:44
If you can't remember how you set up your ATA, then it may just be best to reset it and let it grab a proper DHCP address for its subnet in case you put in a static IP that isn't correct for the subnet it is on now.
And you don't have to specify your WAN IP with Vonage. . .all that should be automatically gotten. And the MAC address is so that the ATA device can be registered on Vonage's network.
