805 router - need ethernet subinterfaces to have IPs & VLANs
Apr 23rd, 2007
I'm accustomed to dealing with much larger routers and I'm hoping that the 805 router is capable of this.
I want to have 2 sub-interfaces (as the router only has one physical interface), and for each to have a different IP address.
The router goes as far as to let me create the interfaces:
interface Ethernet0
no ip address
interface Ethernet0.1
description LAN
interface Ethernet0.2
description WAN
but when I go into any of the sub-interfaces and try to do 'encapsulation dot1q 3' it says unknown command.
Also when I try to just put on an IP address it gives the following error:
805Router(config-subif)#ip address 192.168.8.1 255.255.255.0
% Configuring IP routing on a LAN subinterface is only allowed if that
subinterface is already configured as part of an IEEE 802.10, IEEE 802.1Q,
or ISL vLAN.
So I'm really stuck here.
Any help/suggestions would be greatly appreciated.
The router currently has on c805-sy6-mw.123-22.bin which is IP Plus.
Overall Rating: 5 (2 ratings)
nicolelayne Mon, 04/30/2007 - 19:24
Yes, was afraid of that.
Thanks.
I also tried adding a secondary IP to the interface, but that didn't work either. :-(
