04-23-2007 08:00 PM - edited 03-14-2019 09:07 PM
Hello experts:
I have the following:
2 7941
7941 Number 1 (1002) has 1 DN and BLF for
7941 Number 2 (1003)
When 7941 Number 2, goes OFFHOOK (1003)
BOTH LEDS in -7941 Number 1- turn RED.
Is that normal? Although I only configure BLF for 7941 Number 1 button 2?
Or only BLF led should turn on RED?
Thank you
04-23-2007 08:15 PM
Unless you made a typo in the DNs and they are a shared DN on both 7941s, only the BLF led should turn red.
06-05-2007 03:25 AM
HI all...
I'm also getting the same symptoms... Both of the lines turns red.
I'm using CCM5.1
06-05-2007 04:05 AM
What version of CM 5.1 are you running (Like 5.1.2000.2) etc..
06-05-2007 06:50 AM
Hi There..
Believe it's either 2000.1 or 2000.2
But just to check.. So it's more like a version issue? Can i check the version that u got it workign fine with?
06-05-2007 06:59 AM
I have a 2000.2 which is pretty old version compared to the patch level CM 5.1 is right now at. It works just fine on mine.
06-05-2007 04:15 PM
Hi There..
Sorry. made a mistake.. the one which problem is 5.1.1-3000-5
