Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1926236members
1237822discussions
Community Activity
permit ip ifc outside any any
We have FMC and FTD , In FMC we configured Blocked traffic ACCESS POLICY , but while checking in FTD(CLI) one more ACL( Ifc Outside any any allow) showing with same rule-id 26844160.   any ideas how to find this ACL in FMCACL in FTD ========access-li...
Warranty headache
I have a piece of equipment that support acknowledges to be covered under warranty, but they are refusing to help, as it is allegedly not associated with my CCO ID (even though I deliberately registered it and see it listed). Does anybody have any su...
haramny by Level 1
  • 11 Views
  • 1 replies
new user on Cisco Firepower 1120 unable to https
Team,We have a new Cisco Firepower 1120 just configured with basic configuration.After the admin user I added another user with the "configure user add" command.This new user can SSH to the device but cannot SSL.Further, I want to ensure that this ne...
DMVPN issue with 800 series routers
I have a DMVPN network with 4331 hub routers. Our HQ in Memphis has a hub on AT&T, and another on Lumen. Our New York hub is also a Lumen connection. All are 500Mb up/down. We have about 35 spokes around the US that peer to all 3 routers. BGP is the ...
Recommendation Software ISE
Hi EveryoneOur client for ISE software still uses version 2.6 with pach 10,We will upgrade the software to 3.1 with patch 8, please provide a recommendation link from CiscoI'm afraid that if I downloaded it wrong it would have fatal consequencesThank...
Cisco cellular Gateway stuck in green blinking
Hi all,I am installing a cisco cellular gateway CG522-E and after installing the sim card and powering up, the gateway ends up with the led flashing in green without moving to blue. I have tried removing and reinserting the sim card, powering up agai...
Cisco ISE - Container Storage Space Issue
Hello,Our Cisco ISE HA does suffer from some performance issue and by checking the logs, it became obvious that were are dealing with a space issue: Sending SNMPv2 trap for partition /opt/podman/containers/storage/overlay/...merged which reaches the ...
netmart2 by Level 1
  • 142 Views
  • 3 replies
Secureclient crash on Win11
Hello, I recently installed Secure Client 5.1.2.42 on Win11 23H2 (HU language). Setup was OK, I received no error.After starting the client, the application didn't start, the appl. log shows me the this:The name of the modul, which occured the proble...
TamasMate by Level 1
  • 61 Views
  • 1 replies
Clients only connecting 11a/11g
We currently have two 9800 WLCs serving our schools. Their configs are virtually identical. When clients connect to one specific SSID on 9800 A, they'll connect at expected speeds using 11ac or 11n protocols. However, when clients connect to the same...
Cisco DNA Center Telemetry
Hallo All! What is the reason that when enabling Telemetry on C9300 Series Switches, only Application Name, Usage and Througput are shown? Switches configured with telemetry show only Application Visibility (Name and Throughput) in DNA center. Why is...
