Anand Narayana Mon, 04/23/2007 - 21:51
Hi Amit,
thatz fine abt the link which you hav sent, infact i know that it can be installed on the device, but i wanted to get installed on my windowz XP, does it mean that i can download from the ASA & then 1ly i can install on the windowz XP isn't?
Amit Singh Mon, 04/23/2007 - 22:05
Anand,
If you want to run ASDM locally on your PC, then you need the ASDM launcher to be loaclly installed on the PC. Below are the release note which has the steps to download the ASDM launcher as an aplication on your PC and to manage the security device.
Below are the steps:
Step 1 From a supported web browser on the security appliance network, enter the following URL:
https://interface_ip_address
In transparent firewall mode, enter the management IP address.
Note Be sure to enter https, not http.
Step 2 Click OK or Yes to all prompts, including the name and password prompt. Leave the name and password blank (default).
A page displays with the following buttons:
?Download ASDM Launcher and Start ASDM
?Run ASDM as a Java Applet
Step 3 Click Download ASDM Launcher and Start ASDM.
The installer downloads the file to your PC.
Step 4 Run the installer to install the ASDM Launcher.
http://www.cisco.com/en/US/partner/products/ps6121/prod_release_note09186a0080747e81.html#wp71905
HTH,Please rate if it does.
-amit singh
Anand Narayana Mon, 04/23/2007 - 22:14
K fine Amit,
i could able to install the "asdm-demo521.exe" which i was exactely looking in for. thanks for the info.
lcolbyjr1 Mon, 04/25/2016 - 08:23
Thank you for the link I had already found that site. wich program do I click on there are lots to choose from and I'm not seeing Cisco ASDM anywhere.
MitchellAxtell Wed, 04/27/2016 - 00:10
That's because Cisco's changed their site more than a few times in the past 9 years, when Amit's post was made.
Currently, if you go to cisco.com, and click on "Support", and under "Downloads" type "ASDM", it will auto-fill the "Adaptive Security Device Manager".  Click on that, and it will take you here.
The two options are ASDM and the ASA software.  Pick what's proper for your unit, and as long as you have an active software entitlement contract you can download it.
