Apr 23rd, 2007
Can I configure HSRP in Cisco 3560 switch with standard IOS or is it require to have the enhanced IOS?
THanks and Regards,
Overall Rating: 5 (2 ratings)
ankbhasi Mon, 04/23/2007 - 22:16
Hi Venkat,
It's supported on standard image also.
Amit Singh Mon, 04/23/2007 - 22:17
I think you can run HSRP in the standard image as well. You dont need enhance image for that.
Enhanced image or ip service image support the following L3 features that in ip base:
Dynamic IP routing protocols for load balancing and constructing scalable LANs: Open Shortest Path First (OSPF), Interior Gateway Routing Protocol (IGRP), Enhanced IGRP (EIGRP), and Border Gateway Protocol (BGPv4)
Policy-based Routing (PBR allows superior control by enabling flow redirection regardless of the routing protocol configured
Protocol-Independent Multicast (PIM) for IP multicast routing within a network that enables the network to receive the multicast feed requested and for switches not participating in the multicast to be pruned-support for PIM sparse mode (PIM-SM), PIM dense mode (PIM-DM), and PIM sparse-dense mode
Distance Vector Multicast Routing Protocol (DVMRP) tunneling for interconnecting two multicast-enabled networks across non-multicast networks
You should be able to configure the HSRP with IP BASE.
-amit singh
Anand S Mon, 04/23/2007 - 22:18
Hi Venkat,
if you find the following commands in the interface on ur switch, then there is no necessity for you to upgrade the IOS.
interface vlan 2
ip address
standby 1 ip
standby 1 priority 101
standby 1 timers 5 15
standby 1 preempt.
lemme giv ur feed back on this.
rate this post if satisfied.
Anand S Sat, 04/28/2007 - 07:53
Hi Venkat,
i think you forgot to rate the post, posting the rate will certainly help the ppl. who looks this post in near future for reference.
