How to add user privilege "redirect" to a customize user level access?
arnoldguo
I want to do sth like
sh log | redirect tftp://XXXXX
in a customize user level(<15),
but if I use "privilege exec level X redirect" to add this redirect command to lever X,it's say that " Unknown command 'redirect'" ,how can i add this priviledge to a level user?
Hi there,
Try adding the all keyword:
"privilege exec all level 5 show logging"
HTH, please rate if it does,
Mohammed Mahmoud.
6 Replies 6
mohammedmahmoud
Level 11
Level 11
Hi there,
Thats because there is no command called "redirect", you should put "privilege exec level X show logging".
HTH, please rate if it does help,
Mohammed Mahmoud.
In fact,in this cust user level,user can show log,but can not use sh log | redirect tftp://XXXX,so "privilege exec level X show logging" can not slove this question.What kind of privilege should have to use the redirect comm. ?
Hi there,
Mohammed Mahmoud.
But the "exec all" is not work either.I think it is because such "|" follow redirect command is not the suboption of the previous command.Any more suggestion?
Hi there,
I've tested it for you, and after doing some searchings, using the redirect key word must be done in Privileged EXEC (level 15).
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080110d13.html
Mohammed Mahmoud.
So I have to use EXEC level user to do this thing...
Thanks a lot!
