VOIP Client
Apr 24th, 2007
May I know is it possible using the Cisco 2611XM and CME act as a client with the server which is using Nortel Networks Communication Server 2000? Becuase I join the VOIP service from the provider, I would like to setup VOIP service inside my enviroment.
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Tue, 04/24/2007 - 03:57
Yes, it should be possible. Please send more details, type of equipment and protocols used, etc.
ctohang Tue, 04/24/2007 - 06:09
I would like to use the 3nd party SIP Provider in Hong Kong, is it only need my 2611XM use the IOS with ip Voice and setup and Call manager express server, anything I need to concern or equipment need to be add?
Paolo Bevilacqua Tue, 04/24/2007 - 06:19
No you don't need anything else. However you need a recent version of CCME (I recommend 4.0 or 4.1) and enough flash / ram in the 2611XM to support that.
Is this post useful? Please rate it using the scrollbox below!
ctohang Tue, 04/24/2007 - 06:24
Thanks for your quick reply! How about the Voice mail, is it included?
