Routing between Vlans
Apr 24th, 2007
I have a catalyst 3560G with 3 vlans(Vlan1,Vlan2 and vlan3)and also one trunk port for vlan2 and vlan3.My question is how can i make a routing (Traffic exhange)between Vlan1 and vlan2?
Jon Marshall Tue, 04/24/2007 - 01:16
3560(conf t)# int vlan 1
3560(config-if)# ip address x.x.x.x "subnet mask"
3560(config-if)# no shut
3560(conf t)# int vlan 2
Set your clients default gateway to the relevant vlan interface address ie
clients in vlan 2 have a default-gateway of the address you used when you created the vlan 2 interface.
Jon
nouha1984 Tue, 04/24/2007 - 01:47
This is my Catalyst configuration:
3560-G#sh run
Building configuration...
Current configuration : 2287 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no aaa new-model
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
switchport access vlan 36
switchport mode access
interface GigabitEthernet0/18
interface GigabitEthernet0/19
switchport access vlan 69
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
switchport trunk allowed vlan 36,69
switchport mode trunk
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
no ip address
no ip route-cache
interface Vlan69
ip address 192.168.3.2 255.255.255.0
no ip route-cache
ip default-gateway 192.168.3.1
ip classless
ip http server
where Vlan 36: 192.168.1.0/24
Vlan 1: 192.168.2.0/24
I want to add a new commands to make routing between Vlan 36 and Vlan 1 only for traffic data.
So please can you help me.
Jon Marshall Tue, 04/24/2007 - 01:54
3560(config-if)# ip address 192.168.2.1 255.255.255.0
3560(conf t)# int vlan 36
3560(config-if)# ip address 192.168.1.1 255.255.255.0
Jon
Amit Singh Tue, 04/24/2007 - 01:56
In addition to Jon's post, you have enable " ip routing on the switch as well.You dont have " ip routing" enabled on the switch. Do this:
3560(conf t)# ip routing
3560#Wr mem
You will be good to go.
HTH,Please rate if it does.
-amit singh
desai.jaideep Tue, 04/24/2007 - 01:59
Can u tell that these 3560Gs are connected to which other switches/routers.And moreover how?
Would be better if u would attach your network diagram.
JD
