MeetingPlace Express in VMWare
Apr 24th, 2007
For a demo setup I'm trying to install MeetingPlace Express under VMWare.
The problem is that X window does not support the graphical interface of VMWare, so the X server cannot start.
Because I cannot get access to the OS, I cannot change the settings of X...
Is there a parameter to specify in the .vmx?
I'm using VMWare Server and MeetingPlace Express 1.0.
angelique.devos Tue, 04/24/2007 - 05:01
Problem solved.
Had to login before the error displays and alter /etc/X11/XF86config so screen depth is 24...
andrew.riley Wed, 04/25/2007 - 15:48
Hi There,
I came up against the same problem but found a few other issues.
Did your MPE install work successfully after you changed the colour depth?
I.e. did all services start correctly?
angelique.devos Thu, 04/26/2007 - 00:25
Don't forget to alter the defaultDepth as well.
The only service that won't start is the License Manager, but I'm using the default 6 licenses.
mohsenlotfi Tue, 09/18/2007 - 00:02
I got stuck in first place .
Everytime I try to install the MPE 1.1(4) it gives me an error " This is an invalid Platform for Cisco Unified communication" And no other option ,
How did you passed the HW detection phase ?
I use VMWARE EXS BusLogic with 80GB H.D.D
I even did some change in Cisco/basescript/ and some other files but no luck
Please advice .
