LMS 2.6 Questions
Apr 24th, 2007
Morning,
I have a couple of issues with LMS 2.6.
During discovery LMS picks up a device (actually a lot) 192.168.102.1. I also have a group and credentials set up for 192.168.102.* (this works for some devices).
However my RME failed devices report shows that telnet fails for this device and looking at device center there is only the RO SNMP string in the device credentials.
I would have thought that the Common Services Credentials should be used for this?
if not is there any way of overwriting the credentials so that it DOES use the Common Services values?
also, is there any way of generating an email after a config change? or a daily report containing config changes?
thanks,
Rob
stevejhale Tue, 04/24/2007 - 03:02
I recently went through this scenario, I am in a situation where i wanted to collect inventory for some devices and not configs. The way out for me was to remove the default settings within RME and then apply set jobs with differing criteria to groups. For example I have a group of "telco managed" devices, I only set these to collect inventory (or snmp RO). They then do not attempt to telnet. The global defaults are removed in admin in rme. Regarding config change try the change audit report in RME or even the audit trail if you want specifics regarding who why and when.
rob.ellison Tue, 04/24/2007 - 03:14
i need all my devices to use the setting in Common Services to sync archive. the problem is that at the moment it only uses the global RO SNMP string defined in the Campus Manager discovery settings.
Joe Clarke Tue, 04/24/2007 - 08:53
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You will need to manually specify the additional credentials for your devices in Common Services DCR before applications such as RME will be able to fully manage them. The next release of LMS will offer a default credential system to address this problem, but for now, only the SNMP RO community string will be sent to DCR when discovery completes.
rob.ellison Tue, 04/24/2007 - 09:05
do i have to do this on the individual devices?
it cant be done though groups?
Joe Clarke Tue, 04/24/2007 - 09:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It can be done on groups and against all devices. Just go to Common Services > Device and Credentials > Device Management, select all the devices you want, then click Edit Credentials.
