PRI users authentication
Apr 24th, 2007
Is it possible with two Pri links with one number like 9718000 and one acounting server users authenticate on one Pri and another users on another Pri ?
Thanks.
Overall Rating: 3 (1 ratings)
Richard Burts Tue, 04/24/2007 - 04:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Bahman
I am not sure that I understand your question. If you are asking whether 2 incoming calls (1 on each PRI) can both be authenticated with a single server, then the answer is yes both calls can be authenticated with a single server. If that is not what you were asking then please clarify the question.
Rick
