Create your own custom report template based on your inventory and in the inventory custom template rules pick the following items:
Inventory group: memory
Attribute: Size (MB)
Operator: =
Value: All
Click on Add, then save your changes. You can now go back to the Report generator and it'll show up in the Inventory reports and you can pick the devices you want to report on...
oalvi Tue, 04/24/2007 - 21:19
Thank you very much
Some value of the Routers are N/A, But when I telnet the device I can see this value by sh ver, also in Detailed Device Report.
