Viewing traffic details on an interface
Apr 24th, 2007
I need more details of what is going over my serial interface on my router. I cant remember what the command is to enable logging on an interface so it grabs which protocols are going through it. Can anyone help?
thanks
Mick
Overall Rating: 5 (2 ratings)
royalblues Tue, 04/24/2007 - 05:17
  • Green, 3000 points or more
Mick,
You need to use ip nbar protocol-discovery command on the interface for getting the protocol statistic
you can also configure netflow globally and use the command ip route-cache flow under the interfaces and use either netqos or netflow analyser to analyse the traffic flow
HTH, rate if it does
Narayan
Amit Singh Tue, 04/24/2007 - 05:25
  • Cisco Employee,
Hello Mick,
Which router do you have and what is the IOS you are running on it.
Try enabling " ip accounting " on the serial interface and should show you the desired results.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/products_command_reference_chapter09186a008017d169.html#wp1091971
If you want granular reports, check the netflow support on your routers which will list all the top talkers along with the protocol being used.
HTH,
-amit singh
darkbeatz Tue, 04/24/2007 - 05:34
thank you mate.
I have a cisco 3825 running IOS 12.4
