Unable to Change IP address on my Cisco 7960 phone
Apr 24th, 2007
I had a new Cisco 7960, and I want to change his IP address, but I am unable to do it. The new IP that I assign to the PC is not saved on the phones config, it got baks the IP that was defined by factory.
The steps I do are the following:
- Menu "Network Configuration"
- **# to allow changes on the config
- DHCP Enabled = No
- IP Address =
- Subnet Mask =
- TFTP Server =
Save and Exit
When I come back to the config, the IP has not changed. It still has the original value IP Address = and Subnet Mask=
Any hint ? What I am missing ?
Zin.Karzazi Tue, 04/24/2007 - 05:05
Dont do a Factory reset now, do the following:
setting->Network Configuration->33 (delete configuration) yes and save, then do the same changes above, it should work, if not do a factory reset.
