Abnormal temperature detected
Apr 24th, 2007
A remote side (3550-IOS)has a alert "%PLATFORM_ENV-1-TEMP: Abnormal temperature detected". is any command can show the hardware status related this? or I have to go on-site to check? Thanks
Overall Rating: 5 (1 ratings)
Collin Clark Tue, 04/24/2007 - 05:39
Looks like it's pretty limited. In ISR routers it will report the actual temp, but the 3550 switches just show OK.
TELECOM#sh env ?
all Show all environment status
fan Show fan status
power Show power supply status
rps Show RPS status
temperature Show temperature status
TELECOM#sh env temp
TEMPERATURE is OK
TELECOM#sh env all
FAN is OK
TEMPERATURE is OK
POWER is OK
RPS is NOT PRESENT
HTH and please rate.
