1510 AP Config
Apr 24th, 2007
As a pilot project, I have had 3 1510 APs deployed on my network for about 4 months with no problems.
I'm in the process of adding the rest to have full coverage, but have run into a problem. The AP is talking to the network, getting a DHCP address, but the address keeps incrementing every couple minutes, almost like it's rebooting, but I never lose the link light. It seems like I saw where someone had this problem before.
I've currently got the AP plugged directly into the 3650 switch in my server room, the port is on the correct vlan. The switch is also acting as the dhcp server for this vlan, with the option 43 configured. Everything looks right but I haven't been able to track this down.
Do you guys have any ideas, or remember what we did when you were here???
Randy
b.speltz Mon, 04/30/2007 - 05:50
  • Bronze, 100 points or more
What is the DHCP lease period configured for on the DHCP server? Is the connection stable if you use a static IP address??
ryan@hdn.net Wed, 05/02/2007 - 09:19
I had the same issue. Check to see if your controller is in Master Controller mode. This needs to be enabled while deploying new AP's on the network. Once the 1510 associates, as well as the other AP's you're deploying, you can then disable Master Controller mode.
Ryan
cellxion Wed, 05/02/2007 - 09:30
I had to enter the mac addresses in the mac filter table, everything works now...
