srr-queue bandwidth limit
Apr 24th, 2007
I have WAN links that are ethernet based on gigabit interfaces, but have only 150Mbit/s capacity.
Can i use the "srr queue bandwidth limit" in combination with a priority queue?
Something like this:
srr-queue bandwidth share 1 20 40 40
srr-queue bandwidth shape 10 0 0 0
priority-queue out
srr-queue bandwidth limit 15
Does this make the priority queue 15Mbit/s?
Jacco
Overall Rating: 4 (1 ratings)
royalblues Wed, 04/25/2007 - 07:20
  • Green, 3000 points or more
Jacco,
When you use the srr-queue bandwidth limit, it rate limits the port speed.
So on a 100Mb link this command will limit the rate to 15Mb
All other QoS configurations will be based on this.
so in you example this restricts the port limit to 15MB and not the priority queue alone
HTH, rate if it does
Narayan
